How to adjust lvc cut-out on Arrma Granite blx( newest model) esc RESOLVED
Cam1234
I am aware that currently the lvc cut-out occurs at around 3.7. I would like to lower it to 3.3 or 3.2(because i know this is the lowest you should really go with any lipo). This is because i typically take out my rc for quite long periods of time. So could anyone either give me a step by step explanation on how to or send me a link to a video that explains how to. I am aware that i could find one myself but i feel like this forum knows best when it comes to how to handle arrma cars and i want to make sure that i do it correctly. Thanks.
If you have the BLX100 look in your manual for ESC settings and change to nimh setting but you will now have NO LVC so you will need a lipo voltage alarm you can set to what voltage it will sound and tell you pretty much to stop at.
Thank you. However, is this really the only way that i can do this?
Yep there is not a way to set LVC unless you get a different ESC from either Castle or Hobbywing I believe, but can only turn it off on the BLX100 by changing it to nimh setting
OK. So how much are these lipo voltage alarms. Can you recommend one?
just realised i already have one of those. How do you make it work. I tried and kinda failed.
Plug it into the balance plug on the lipo is all you have to do after setting the desired voltage for the alarm to sound.
3.2/3.3 is really low, even if you could adjust the esc, I wouldn't go that low.
