Been doing it for the last ~ 4 month. Check my build log for parts. The ones I use come with bare wires i.e. some work required.
Long screws is all you need, they screw directly into the standard 35mm fan locations and have sufficient cooling on standard BEC voltage. Running them on 12V will cool everything you ever need.
Great video, thanks for sharing. Is this fan made in a 50 mm version to bolt directly onto the Kraton 8S motor heat sink?
