SébastienSebior
- Kraton 6s
Hi, Please help. I have my 6s warming up, and I need some tips to mount a fan . What can I use, which model and what is the best to cool it ?
thx
Seb
thx
Seb
Yep sure is. There’s a light blue if anyone is wonderingIs this the fan set up your talking about @Overpowerrc ? I need to get these as well.
https://www.amainhobbies.com/yeah-r...vtO10IJlYAgRMEK3wPUXvIiA7VDDdmAcaAgTTEALw_wcB
I run the yeah racing dual fan setup in my Mojave and they kept the motor at around 160F when I was clocking 200F before. Crazy 40F difference!!Yeah racing dual fans or powerhobby dual fans
Just have to make sure to use the spacers to avoid motor interference!I run the yeah racing dual fan setup in my Mojave and they kept the motor at around 160F when I was clocking 200F before. Crazy 40F difference!!
Motor interference?? ? please explainI run the yeah racing dual fan setup in my Mojave and they kept the motor at around 160F when I was clocking 200F before. Crazy 40F difference!!
motor interference?
Maybe he's talking about the magnets in the motor interfering with the fans..???
Yes! The magnets in the big motor will stop the motor in the smaller fan. Especially if you are full throttle. Also if you notice that your fan stopped working after some bashing simply stick your hand underneath the body and start the fan manually and for me it would start spinning again.motor interference?
They also remove any motor interference with the added space inbetween the motor.pretty sure the spacers are to add efficiency to the airflow. A makeshift venturi effect without a venturi.....
Check out amazon that’s where I bought mine.I do not see any interference with a fan !? any news ? I have trouble to find the Yeah racing fan for the time being...
gotcha. my kit only came w 4 spacers. which i assumed were not for the fans but the screws and the heatsink piecesYes! The magnets in the big motor will stop the motor in the smaller fan. Especially if you are full throttle. Also if you notice that your fan stopped working after some bashing simply stick your hand underneath the body and start the fan manually and for me it would start spinning again.
When I use the spacers I didn’t get any interference no need to be paranoid haha
No use two spacers and the two long screws per fan screw them at a diagonal and just two work fine.gotcha. my kit only came w 4 spacers. which i assumed were not for the fans but the screws and the heatsink pieces
Yea, that was the only thing I could think of as well. Kinda makes sense ?Maybe he's talking about the magnets in the motor interfering with the fans..???
