chris.dempsey
Last time I had the Kraton 6s out the rear wheels developed a wobble. The car was fine beforehand and all we did was run it on tarmac with a single 3s so the kid could have a shot. Only thing I can think that may have contributed was a few dozen hard turns, soimetimes under a fair bit of power and mostly to the right.
After taking the wheels off I can see that the red wheel hex nut has about 1mm movement side to side and the the rear hub assembly AR330404 has around 0.5mm movement. The lower suspension arm AR330249 has 2mm movement front to back.
Can anyone suggest if I just need to tighten the bolts on both sides of the suspension arms or is there something else I need to look at? Just looking for advice before I start touching stuff, first car, zero experience and all.
