- Granite
- Notorious
Eh it's angled a little bit but it hasn't hurt anything.I can try the Monster Dork option to really get the whole system line up right so we don't have any difference between left and right for starters.
And for Crunchy Maybe it's not relevant for this issue but I made a picture from the horn that came with the servo. Here you see that the angle towards the servo saver is way of when you mount it on top. On the downside of the horn there is no space then you are stuck on the servo itself. So I really think the cars are not the same? Can you make a picture from your servo/horn/saver connection just to be sure?
For new readers: This is not the problem just a sub question for Crunchy!
Stock linkages. The arm runs the entire range of motion with the stock horn.
I mean this is technically true, but most transmitter trims have enough adjustment to be centered that way, long as you get it close. If the SLT3 can, the "better" dxc3 should be able to as well?More travel is gained through a longer horn.
Centering is mechanical first. That means you center the servo horn how you like it, and adjust the front turnbuckles to line up right. This works every time, because you are centering the wheels to the servo's midpoint.
