Hello everyone I finally received my Arrma talion v3 and the stickers but I do not know how to connect the dual fan of yeah racing (do you need other electric wires to buy?).
Thank you for your answers
Is that a JST Y harness ????
Doesn't the year racing heat sync have 2 fans with 2 plugs? If so, to use the esc fan port, you would need 2 Y connectors. Or find a 3->1 connector. Or make a 3->1 connector. Considering how easy fans die, your best not to solder them all together and use a connector of some sort.
Like one of these:
https://www.motionrc.com/collection.../products/150mm-6-3-way-servo-extension-cable
https://www.amazon.com/Products-Triple-3-Way-Extension-Futaba/dp/B06XKHWGNK
If he wanted to use the fan port on the esc itself vs running to the receiver box.If there's 2 plugs going into a single port on the ESC why would you need two Y connectors? You plug each fan into the double side of the Y connector and then plug the single side into the ESC or into the receiver.
