jsytaz
- Kraton 4s
So I know about charging with a proper charger at the correct rate and all that, and that you should “storage charge” when not using for awhile. I have a protek rc prodigy charger which makes it easy. So my question is about charging a lipo when it’s not “dead” Say I properly charge up my 4s and go out for a run but I don’t have enough time to run the battery till the esc cuts off at low voltage. So the battery still has some life. Do I have to discharge on storing mode before re balance charging it to full capacity? Or can I just throw it on a balance charge as is the next day or 2 and be good to go?
