Emery Hall
- Outcast 4s
How can I put this screw back in the little cup to screw into the hex?
Yes sit holds the the driveshaft to the hexIs that from inside the hex?
The drive shaft popped out and my wheel but was stripped so I went in from the inside and removed it that wayBetter question is how did you get it out?
Then just reverse what you did to get it out. I assume you need to remove the yoke from the section that holds the axle. The hole in the yoke is too small to get a screw thru.The drive shaft popped out and my wheel but was stripped so I went in from the inside and removed it that way
