Senton How to remove the pinion...?
pl9171
Canada
Senton
Hi!
Case is open and removed. Cup screw in the rear is removed too. Pull the rear cup…?
Hidden screw…?
Thanks a lot
PL
JvG
Everything is relative
The Netherlands
Kraton 6s, Typhon 6s
The input cup on the other side has a screw. It can be quite hard to losen it the first time because Arrma uses a lot of red loctite on it. Use heat to get the job done.
Mr.Duke
~ Likes to 👨‍🌾 farm in flip flops ~
ArrmaForum Fan
NC
Notorious, Talion
Use heat and then tap it through the back of the diff with a small brass punch, but not too hard or it will kill the front diff bearing. If tapping doesn't push it through, apply more heat with a soldering iron through the grub screw hole and the tip of the pinion stuck in the cup. It can take a couple minutes so if youre unsure how much heat the pinion is absorbing, place your finger tip on the pinion gears and gauge that way or smell around it for the threadlock to start cooking.
pl9171
Canada
Senton
Ok, I see the gymnastic.
Thanks
PL
pl9171
Canada
Senton
Finally, I got it… What is the red stuff inside the cup…? Glue…? The cup was really stick to the pinion.
Have a nice day.
PL
bicketybam
BickeringBam - YouTube Mega Star!
ArrmaForum Fan
New Milford, CT
BigRock 4x4, Granite, Notorious, Talion
Red loctite (thread lock).
pl9171
Canada
Senton
Ok...
(it was really stuck)
Thanks
joostin420
MA/NH
Fazon, , , Senton,
Make sure you clean it up prior to reinstalling. I had to use an exacto knife to get the old red loctite out and off the pieces.
pl9171
Canada
Senton
Good point.
Thanks
PL
olds97_lss
Bash Break Repeat!
Dekalb, IL
I was lazy and just hit the end of the cup with a pencil torch. LOL!
Had to do the same thing to get my MIP's off my stupid stampede 4x4 diffs last night. That was with blue gel locktite!
pl9171
Canada
Senton
yea....its used on all the pinions. Red loctite is "permanent" according to Loctite. Not my favorite move by Arrma.
Do you add red loctite when you reinstall the pinion…?
Thanks
PL
joostin420
MA/NH
Fazon, , , Senton,
I use blue when reinstalling items that originally had red loctite. Just be sure to wait the 24 hours to garauntee it is cured.
pl9171
Canada
Senton
Ok, did the same with RC4WD blue threadlock...
Thanks
PL
Similar threads
