Keitarono
- BigRock 4x4
- Senton 3s
I recently was out running my Senton when the slipper came loose. I tried to tighten it back up, but when I did, I snapped the little screw in the slipper. Since it was stuck in the metal part of the slipper, I had to order a new slipper. When that one came, I found that it wouldn't fit in my V2 Senton 3S without removing that small black plastic piece in the slipper. I removed that, tightened the slipper up, not so tight this time, and gave the car a run. I noticed that the slipper was slipping way too much. I took it out, turned the screw a couple turns, and it snapped off again.
Is there a way to stop snapping that screw inside the slipper and still get it tight? Does the little black peice somehow keep the screw from snapping when tightened in the newer slippers?
