Hi got the 2200kv hobbywing motor in the senton now doing some open park bashing. the suspension is lowered running soft setup min preload on rear springs max droop front and rear and 19t pinion with badlands. No matter what speed im doing soon as i hit the throttle flat it wheelies straight up in the air like a rocket. fun to watch but not fun to drive fast accross the park. Im using graphine 65c 2x3s lipos and the punch setting on the max 8 is on max. So do i lower the punch setting, go bigger pinion, not sure what to do to keep the front down. I don't mind a bit of wheelies but this is....
