Mr.Duke
Moderator
Community Leader
ArrmaForum Fan
- NC
- Infraction
- Limitless
- Kraton 6s
- Notorious
- Outcast 6s
- Talion
- Typhon 6s
I know I’ve covered this before but I think it was in the “what did you work on today” thread so I’ll make a dedicated thread on how to do this here since that’s what I’m working on at the moment.
If you haven’t bent a driveshaft or dog bone yet, give it some time, you’ll bend one eventually.
Yesterday I noticed that one of my rear shafts was bent, so here’s how I straighten them back out.
It’s an old man trick that I learned a long time ago called “the 3 bolt method”.
You will need a vice, 3 random bolts (doesn’t really matter what size) and a bent shaft.
Take your 3 bolts and arrange them in the vice like so...
Hold the position of the bolts and open the vice so that you can slide the shaft in between the 3 with the arch of the bend resting against the singe bolt
slowly close the vice and watch the shaft as you just want to hyperextend the bend in the opposite direction. Go slow, you can snap the shaft if you bend it back too much. Take the pressure off and see where the shaft flexes back. Repeat this process until it’s perfectly straight again.
Some are easy and you get it on one or two tries. Sometimes it takes a dozen or so before you find just the right amount of pressure needed to straighten it.
Done, and good as new.
Hope this helps.
Hope this helps.
