That video has some good info in it. I disagree with the sway bar part of it though. I ran mine with out the sway bars for a while and though I got used to it, but when Hot racing came out with the aluminum sway bar retainers, I tried them out again. I did swap to the thinner/weaker versions, But I like how it handles with the sway bars in place. Otherwise when it digs into the corners the lack of sway bars allows it to traction roll much easier. The sway bars prevent the body roll and force a slide, which helps me keep all 4 wheels on the ground. Also if you are worried about getting up that curb, then buy a rock crawler. I know my Kraton has no issue getting up curbs way bigger than that one. I run 500K center and a mix of 100k and 70k in the front and rear. The Kraton tires are great for running parking lots and street runs, only because you already have them and, don't want to mess up your good offroad tires on the street. But once you wear them flat, just get some SRC's for the road.
