- Coming around to lap you AGAIN
- Kraton 6s
- Senton 3s
You may have just bought a new arrma granite or maybe a kraton but just broke it and are wondering how should I upgrade my rc car to make it even stronger?
Well first of all you need to be carefull what you upgrade because certain upgrades may weaken your rc car and obviously you don’t want to do that.
first step identify why it broke. Was it user error? or was it your just driving it on edge like it’s indestructible? These are the most common reasons why your car would break. But there are some rare cases where its actually the cars fault. I will discuss with you all on how and why you should or why you shouldn’t upgrade it
most likely if you broke your car it’s because your pushing it to hard if you want to continue doing that then you may want some upgrades here is some and why or why you shouldn’t upgrade them
Chassis: Arrma’s metal chassis’s are notorious for bending but we can prevent that by changing the stock plastic braces to aluminum or we can upgrade the chassis with something called a bash bar which is a metal bar that bolts on to your chassis making super tough. My personal favorite way to upgrade a chassis is to get a stronger chassis which you can find online. Brands I recommend are scorched rc and m2c racing.
A arms: This one is a big issue when it comes to upgrading. There are many way you can upgrade the arms i recommend upgrading to RPM racing arms due to them being flexible light and tough. If your car is a rare case where RPM is not an option then you probably have a race grade car which the manufacturer may sell different arms for the same car and this is due to the compound that there made out of normally its either a soft or hard compound im not to get in detail about that here but it’s pretty much this hot outside then (hard compound), cold outside (soft compound).
Metal arms you almost never want them they wI’ll put strain all over your car where your arms would normally absorb. The only situation you would want them is for a Shelf queen and that’s about it.
Shock Towers: now this is a tricky one but I’m going to make it simple. If it’s plastic keep it plastic and your probably not gonna have much issues with them. But if it’s metal your probable going to want to have something stronger because it’s most likely going to bend unfortunately there are little options for bracing (the only tower brace I know of is one made by m2c racing but thats all I know of at this point of time.) so your probably gonna want to upgrade that and brand i recommend are Basherqueen, M2c racing, scorched rc.
(solid axle rc cars) (not crawlers)Axles: In most cases your axle will crack from hard bashing and your going to want to upgrade this to aluminum it will be expensive but worth it.
Turnbuckles: normally they don’t break but you can upgrade them but I don’t recommend this because they normally don’t break there are upgrades but im not going to cover this because normally the stock ones are plenty durable.
Servos: we all know the stock servos are weak and have a tendency to die there are almost no downsides to upgrading your servo there are many many options out there depending on your budget but here are some brands i recommended then you decide what specs you want savox, perfect pass, eco boost. Don’t forget to set you end point it stop your servo from oversteering preventing unnecessary damage to your servo (not all remotes support endpoints) you can search how to set endpoints on YouTube for tutorials
3s line driveshafts: They break when you convert your car to brushless or are brushless they pop out of the cross joint and there aren’t many upgrades for them that are consistently working but there are some fixes you can do put heatsink over the joint or you can zip tie over the cross joint. Other members may have other solutions for this specific problem
Please leave recommendations for this thread so I can update it and make it more useful for those who need it.
