Eastwolf1228
Hi thereFor guys that need some tubing or fuel line to buffer aftermarket shocks for BLX 1:10, this is what you're looking for. Works perfectly. Screw fits tight and will take some finagling to get through but eventually a great fit for top of the shocks in the shock tower. I had to grab some tonight from Home Depot and $6 gets you 10' of the stuff. You'll need less than an inch per truck but good to have around in case your weed eater, chainsaw, leaf blower needs fixing. Or maybe you have a gasser or nitro collecting dust?...lol.....I wouldnt know.
I searched for 4mm first and ended up buying 3/16".
Doing the HR c-hubs, AVID bearings and aftermarket aluminum shocks on brcc. 50wt shock oil.
Anyway, second photo is the Home Depot tubing product:
View attachment 32609View attachment 32608
How are you finding these Silver shocks with 50wt oil?
I'm surprised (a little disappointed) about how stiff these things are:
- I've used 50wt and then 40wt (marginally better)... if I drop the truck from a foot high on to concrete, it just bounces on its tyres and the shocks don't move. Then if I drop it from say 2 feet high or more the chassis slaps on the floor.
- Note that "at rest", the shocks remain at about 60-70% of standard height - as in, they sink a bit which looks mean, but I'm sure they weren't designed to do that! [A-arms remain horizontal to the ground, like a Notorious etc]
- Slightly shorter than stock height.... Pics are against the purple HSP ones I've documented earlier in this thread, which I've matched the height to stock 99% accurately
I read someones's post that these silver bigbores work better with the stock springs in them.
All good fun but emptying and replacing shock oil is getting tiring!
The sagging could be remedied by using a stiffer spring I know..... I quite like the height.
Let me know how yours is performing please.
