I'm sure you could but @Mr.Duke is the man to correctly answer this question ...wait for his response brother ?I'm going to give this a go soon myself ??Ok, thanks one more question. Can you still mask the windows so they come out clear?
@3dplank ...see? I told you he was THE MAN! ❤??Yes, masking works just like in traditional paint application, but once it's wet needs to be replaced once the body is dry from the dipping process. You'd tape the windows, dip the body and wash with warm water for 5 minutes to remove all of the film and chemical residuals. At this point your tape job will start to unpeel and need to be taken off to clean the clear areas under the tape. Carefully reapply tape to the same area as before after the body has time to completely dry, then proceed to apply your base coats.
Seriously bro??? It's just the truth!!! I'll be pming you on how to do this soon. ??????You're too kind sir.
Thank you
I like the black roof!???Thanks, I messed up the roof, so I painted it all black.
Looks good! If you hadn't said it, I would have just kept thinking the black roof was intentional. ???Well first hydro dip done. Made a few mistakes. Learned from them. It came out pretty good for first one.
Looks great!I did a typhon 3s body. Dam air bubbles in the roof. Paint it black. I have to adjust my dipping angle to get the roof air bubble out. I think it turned out cool though.
