Whats a good iron and whats a good tutorial channel on line?
I have a cheap setup from harbor freight which seems underpowered
This is what I use works greatI have owned over a dozen stations. Best bang for the buck if you are serious is a trakpower 950 with a 2mm and 5mm tip that's all I ever use for this hobby. Good liquid flux and not all solder is the same. Get a small desk air filter and you are set to do everything you can get everything for just under $100. If you decide to go that route I can send you the stl file for a setup I made for it.
