- Limitless
- Nero
- Talion
- Thread starter
- #41
Any specific one?Skid plates? Will protect the bottom.
That will fit stock mount and plate just fineI was thinking a max6 combo is what I would put on. Would that fit the 4985? I have heard is basically the same as spektrum.
Idk how well it would work you are definitely going to drag the front wheels until the diff starts working did you buy the diff for your limitless? I just got one as well and may just be changing the spur gear and keeping the spoolWill the handbrake work with an almost locked center diff?
I bought a center diff from JRC. I was going to silicon earplug it, but I want it to work like a normal HB and not lock all 4 wheels.Idk how well it would work you are definitely going to drag the front wheels until the diff starts working did you buy the diff for your limitless? I just got one as well and may just be changing the spur gear and keeping the spool
The handbrake will always lock all four wheels. It stops the center diff from rotating so there's really no way to keep it from affecting the front wheels. But it behaves as though you're just locking up the rear.I bought a center diff from JRC. I was going to silicon earplug it, but I want it to work like a normal HB and not lock all 4 wheels.
Not that I'm aware of.Are there any custom rear driveshafts for the v2 limitless that allow for the use of a regular center diff or spool?
