Granite I think I came up with a solution for the cvd drive shaft to quit popping out
Karanicasscotty@gmai
Fla
  1. 4x4-Mega
  2. Granite
  3. Kraton 8S
  4. Kraton 6s
  5. Kraton EXB
  6. Kraton 4s
  7. Outcast 8s
  8. Outcast 6s
  9. Outcast 4s
  10. Typhon 3s
I got this truck running about 80 miles an hour then they'll keep up with my kraton 6s but I will let you know if this works or not here in about an hour few hours when I put these on imma give it hell and see
Looks great, but you could also get the Arrma upgraded cvds.
Going to was a guick fix, and actually is still holding up pretty good. Ran it today on 5s didnt come apart. And was on the trigger pretty heavy trying to get it to give
Which ones
Talking about this set up?
Read that thread I linked it explains how to do it.
Yeah I read that he's using the 4S ones and then he's using the other three as ones I was just hoping maybe just to use those I'll figure it out though you pretty much gave me an idea though I appreciate it man
The only way you can use just the 4s ones is to replace the entire suspension with the 4s suspension ie a arms, turnbuckles, hubs and caster blocks.
Good idea but doesn't address the weak point being the ears you drove the screw through. Never broke anything else on my driveshafts but those ears and I'd think the thicker screw just made them even weaker as now there's less plastic holding it together.
LOL it is broke snapped them off. Looking to make it a Lil bit stronger
Yea that's what happened, was trying to figure out something stronger I had laying around
Upgraded to the arrma kraton 4S cvd sliders and, the kraton 4S rear hub carriers. Lil modification but they work good and man I love it won't have to worry about that rear end breaking no more that's for sure
These should work rt just cut them to rt size
Made them work just put the 4s rear hub carriers with them with a little modification man awesome
Here's another shot of what I did just in case somebody wants to do the same thing
So these aren’t 4s arms? Just the rear hub carriers?
They are the typhoon 3s arms and everything I cut the for Creighton DVD axles down and put the 4S kraton Hub carriers on them
I mean yeah you could add the 4S arms and everything else and it'll work to it would keep your CBDs a little longer also
