How do you turn down motor timing? And what kind of fans?21t if you have sufficient fans for the motor and ESC.. 19t if you don't.. turn your motor timing down as well, it's set to high from factory causing excessive heat.. try not to run anymore than 15*..
Esc programmingHow do you turn down motor timing? And what kind of fans?
I bought mine used. Lol I’m the dumb one that didn’t know that’s a thing. Is there a simple how to? And what does this do?
To be fair I can’t fix what isn’t broke yet. Lead me not into temptation… I will find it myselfI foresee a crisp spektrum esc in your future.![]()
The rabbit hole I’m diving in right now. My mind is blown. Thank you and really everyone. You guys rock.Look up the manual or watch videos on how to change the parameter in the esc... Can be done through the set button or you can buy a programmer... Your esc is most likely in the 22* range from factory.. makes far to much heat for street bashing..
40mm fan on the esc and 2 40mm fans on the motor...![]()
So...you're strictly overhand?If I’m at someone else’s house and their toilet paper is pointed the wrong way, I remove the roll and flip it around.
Felt good to get that deepest darkest secret off my chest!
