Boodaggy
Have you figured anything out about a resistor bank? I built one myself but am trying to refine it. I pushed the last one to hard and burnt up the resistors haha.iCharger duos have massively high discharge capabilities when using an external resistor or battery in the second channel to do a regenerative discharge. It would let me put like 8 batteries in parallel and discharge to storage in the time of one. If you use the inbuilt resistors on the charger I believe you are limited to a 80w asynchronous 125w synchronous discharge vs a 40a 1400w discharge (the same as it's charge specs). Thats my main reason. With a good setup you could even fully cycle a full balance board of packs from storage to full to storage in a relatively short amount of time.
