- Thread starter
- #21
Can you see it ? Did i find a burned coil?
Its happening with all my lipos now and acceleration is terrible and lipos don't get hot. I don't belive in batrry problems because i have been running under the recommandation ratings on my kraton 4s and it never had issues and the lipos are all still healthty. Even if it was the lipos they didnt puff up in fact i never had a lipo puff on me yet.Second the batteries being the problem, hope it works out for u ?
I already ordered the firma 2050kv waiting for it to come next week. The problem just kept getting worst. Hrb lipo brand is known to be a powerful budget lipo zeee and awanfi are under performing zeee not too much but the awanfis yes pretty badly. The cogging was almost gone on the awanfis.Could u perhaps borrow some higher rated batteries to see if you could eliminate that problem? Could your lhs maybe help you out?
Yes it does roll freelyDoes it roll smooth with the pinion off?
And if you spin the front tires the opposite direction?Yes it does roll freely
What do you mean?And if you spin the front tires the opposite direction?
Turn the front left wheel forward and the front right backwards. How does that feel?What do you mean?
Feels goodTurn the front left wheel forward and the front right backwards. How does that feel?
And the same for the rear? Then hold the rear tires up off the ground and roll it on the front tires to check the center diff. See is any feel notchy or problematic.Feels good
Alright i will. But i checked and rebuilded the center diff like not long ago 3 packs. Everything was fineAnd the same for the rear? Then hold the rear tires up off the ground and roll it on the front tires to check the center diff. See is any feel notchy or problematic.
I jamed the mesh between the spur and pinion and rotated the center diff. Front and rear spinning at opposite directionsAnd the same for the rear? Then hold the rear tires up off the ground and roll it on the front tires to check the center diff. See is any feel notchy or problematic.
You’ve got a diff in backwardsI jamed the mesh between the spur and pinion and rotated the center diff. Front and rear spinning at opposite directions
Impossible you know how a differential works right? If you spin one drive cup one way the orher spins in the opposite way all 4 tires spin one direçtionYou’ve got a diff in backwards
Maybe it’s late and I’m missing what you’re trying to say, but you said you moved the center diff and the front and rear moved opposite directions?Impossible you know how a differential works right? If you spin one drive cup one way the orher spins in the opposite way all 4 tires spin one direçtion
