I'm working on a motor slider plate for the K8s! It will be a standard motor plate intended for big can motors with 8mm shafts and 30mm screw spacing ONLY. It should accommodate a 62mm diameter motor, and will allow a pinion range from 18-42 teeth on a 47t spur.
They will be a replacement insert for the factory mount. I simply do not have a K8s of my own to 100% verify fitment so I need a couple people to test them.
To qualify:
You must have a K8s.
You must have a large can motor up to 62mm diameter with 30mm screw spacing in your posession.
You must have a build thread.
Must be able to install within a day or two after receiving the part.
This is a simple situation where I'll send you my part, you install it, and tell me if it fits correctly. You'll keep the part for your trouble.
If you're seriously interested, shoot me a message!
To qualify:
