Kraton Increase ESC cooling airflow
The HRC 35mm ones spin at the same speed as an original fan it seems..
Are there other brands that move a lot of air or do i need to start thinking about an adapter?
Hi, are you sure about it? This is a 24.000 rpm fan:
Ventilator 35x35 - HRC Typhoon RC Fan - Ultra High Speed - JR Plug
Fan size: 35X35mmX10mm
RPM: 24000
Current: [email protected]
Weight: 10 g
Input voltage: 6.0 - 8.4V
I was able to compare with my MAX6 ESC but the difference was really noticeable. I guess you have a BLX185 ESC and I think the HRC has higher RPM than the stock BLX185 fan.
