Information spur Gear limtless
32.
Good morning everyone, I have just completed my limited fast configuration..1721 2400kv,xlx2,2xcnhl 120c but I would like to start with a spur gear larger than 39 teeth and I was wondering if any of you could tell me if it existed
Someone can correct me if I’m wrong, but I believe you’re kind of limited on choices when using the stock spool.
If you are running an aftermarket spool you can use any 8mm bore pinion from companies like Saga RC or Radiocontrolpower.
Have you gone to Arrma’s website and looked at the optional parts for your Limitless?
