Clancman
- Granite
Hey guys just wanted let you know I upgraded my ESC to a Hobbywing MAX6 and this thing is an unreal beast. I did it out of necessity because my stock one fried out on me(of course! It’s my 2nd torched stock ESC on my 6S rigs). The other one was from one of my Kraton’s. Anyway just wanted to share that this is my first run with a Hobbywing ESC as I’ve replaced my Kraton’s both with Castle MMX’s and I gotta tell ya this thing is impressive. I run the piss out of rigs on 6S SMC 7400mah 90C’s and usually push my rigs to the limit and have never had a Castle ESC fail me so I’m hoping the same is true with this MAX6. Got almost 7 packs out of the stock ESC before it crapped out. Running the 27T on an 90 degree day and she finally gave up. Temps were high 180’s low 190’s which I knew wasn’t good. I’ve ran 4 complete packs through the MAX6 at anywhere from 85 to 90 degrees out as hard as I normally run and I’m gettin max temps only in the upper 140’s which blows me away. Not coming close to thermal shut off. Just stoked about this ESC and wanted to share in case anyone else was having issues. I swapped in one of my MMX’s while waiting for my Max6 and was gettin high 170’s and low 180’s so it was pushing the hell out of the MMX. Ran about 5-6 packs through the MMX. If your thinking about an upgrade or are having issues give this beast a look. You’ll be real happy you did. Mine was $169. Also I adjusted my ride height up in the front end a smidge(about 5 and a half turns a side from stock height) and it’s perfect! Nowhere near as much scraping and rubbing. Try it if you haven’t. Check out my new friend and size difference over the MMX. Happy ripping gents.
