I’m not sure why you would want to use that instead of the motor? What are you looking to accomplish? The motor will work much better as the main braking system.Thinking of trying the hand brake to see if it will work as a brake instead of using the motor.
Just thinking less heat on the motor less annoying breaking sound but will have to get creative with using reverse.I’m not sure why you would want to use that instead of the motor? What are you looking to accomplish? The motor will work much better as the main braking system.
Yep you need the Mugen drive cups.It could but that center diff will heat up and you probably need to limit the servo travel so you don’t clamp down hard on the disc.
I believe @jondilly1974 was implementing something similar with a center spool.
