Are you talking about the full size infraction or mini infraction?I don't know if this is possible on the Vendetta as I don't have one. On my Infraction I modified the front hinge pin holder of the rear suspension arms by drilling two holes just outside of, slightly overlapping with the original holes to give me zero toe on the rear wheels. The holes look approximately like this.
I then ground down some appropriately sized grub screws on one side which I then use to plug the hole that the hinge pin is not in to prevent it from accidentally slipping over into the other hole. Like said, I don't know if the hinge pin holders on the Vendetta would be accommodating to such a modification, but I thought I'd throw what I did out there. This may, however, reduce rear end stability of the car. My Infraction drives like its on rails...which I attribute, in part, to the vertical fins I put on the Ford C100 body and in part to a good setup and dialed in suspension.
The 1/7 scale Infraction.Are you talking about the full size infraction or mini infraction?
Ahh okay. The OP meant the mini infraction, like what I have. Bummer, I’d love to get rid of the toe in.The 1/7 scale Infraction.
