Infraction Infraction v2
ianb171
My infraction v2goes through its six bleeps then nothing hand brake servo works but no steering of throttle run it fo far 4 times only changed fan from single to double. Any ideas please
Unplug your steering servo and see if that will fix the problem.
Is the ESC blinking red as well?
Most likely a bad servo causing the issue, but that is an easy check.
Ah, right thanks. No not blinking red flashing green then nothing I will try servo tomorrow
Cheers
Ian
