Infraction v2
So far i have v2 infractio. Running x2 35mm 21,000 rpm fans! Also scorched underbody plastics. Skid plates and underbody skin! But what else should i buy next?
Thanks
Depends on what you want to do... Speed runs or drift bashing both require a different way to build your RC.
The best advice is to stop where you are at, run it, and see what you want it to do or lack of.
With all rigs...maintenance, tires, bearings, fluids, etc, good to have, and make sure they are topped off
How often do you change fluids?
The official recommendation in the manual:
In reality, its completely up to you, how often you drive, and how you drive. Myself personally, I don't drive very often, I change the fluids in all my vehicles once a year during the Chicago winter. Once the salt hits the streets, I'm done driving until the first major rain of the spring washes it all away to avoid corrosion as much as possible.
What the other user said below.... I follow the manual, and if no manual, I still follow the posted manual by the use for all my rigs
