basher27
After recently rebuilding my differential I used some marine grease to coat the input gear and ring gear with. About a month later I now took it apart and noticed that there doesn’t seem to be much grease on the teeth. Does anyone know if this is normal or is there a better type of lube that should be used? Thank you
