kbizzle89
Does anyone know a easy way to remove the grub screw from the input gear/diff cup that connects to the rest of the drive train? I def stripped it out and trying to figure how to remove it.
Which extractor kit do you have? I tried one of the Amazon kits a while back and wasn’t impressed.I have usually used a damaged screw extractor set with decent success, and recently got a pen torch to help with the ones caused by excess loctite.
I got mine on Amazon in 2019. The brand is called 'TackLife' but it is no longer available on AMZ. I have mostly used it on things like 2.0 and 2.5mm cap screws I put too much Loctite on, which held things to my aluminum shock towers, hubs, etc. I try and stay away from too many metal parts (especially if they connect to other metal parts) on my cars anymore as a result.Which extractor kit do you have? I tried one of the Amazon kits a while back and wasn’t impressed.
