So i installed my hot racing diff case. who was a pain in the butt because tolerances. I noticed a lot of up and down play on the input gear even if i push to the max the output cup i tested with the stock housing theres no play at all. Whats exactly the size of shims i need to take the slop out? Depends where i put the shim on the back or in the front of the input shaft
