MeesterC
Hello all,
I have read numerous threads about installing the outcast battery tray in the kraton. Most have said that you needed to drill new holes for the outcast tray to fit. Well, I have just installed two of them, one in a senton and the other in the kraton. No modifications at all were needed, both installed perfectly just like the factory one. First you need to attach the receiver mount on the tray, once mounted line up the receiver mount with the chassis and install the screw loosely. Once this is done the tray will line up with the correct holes and sit in the chassis, install the remaining four screws and your done. Don't forget to install the straps first though. Like I have said, I have just installed two with absolutely no modifications at all.........
