Came across these today, whats the scoop on these?
https://www.integy.com/st_prod.html?p_prodid=39980&p_catid=492#.YmbOMN8pA0E
No leaking?I use these on all of my 3S models, and I haven't any problems with them. You can't beat the price!
https://www.ebay.com/itm/2844386856..._QqxDlegQ9-&var=&widget_ver=artemis&media=SMS
Good tip I have been looking at them for my 3s sI use these on all of my 3S models, and I haven't had any problems with them. You can't beat the price!
Awesome. And they’ve also been pretty durable?No leaking at all.
Yes, they have been very durable. I haven't bent any shock shafts, no leakages, and no broken rod ends.Awesome. And they’ve also been pretty durable?
Integy is know for making bling parts, their shocks are known to not be one of the items that are best suited for a shelf queen, the shocks often rarely function properly and leak.
I would avoid all and any of the cheap shocks from Amazon and eBay to be completely honest. Buy cheap buy twice.
Maybe Arrma should start using these "Cheap Ebay Shocks" on their 3S line. Aluminum bodies, aluminum caps, 4.2 mm shafts, and they don't leak.
I bought my first set of "Cheap Ebay Shocks" on September 7th 2020, and they're still going strong. No problems, no leaks, and no breakages. I bought cheap and only bought once.
I guess I'm super lucky, and you have bad luck. I purchased four sets of these shocks and all four sets are amazing. It's weird how you had every problem that I haven't.Couldn't pay me to use another pair of that guys shocks.
Mine leaked, they were a pain to bleed, the springs were too stiff, the rod ends were trash and the shafts bent. I'll pass. I'm not the only one who has had issues with those shocks. I've seen numerous people post that their pistons were mismatched.
Idk unless they changed the design since I bought mine. You mentioned yours had 4.2mm shafts, mine are 5mm. Do they still not come with bladders and is the cap still unvented?I guess I'm super lucky, and you have bad luck. I purchased four sets of these shocks and all four sets are amazing. It's weird how you had every problem that I haven't.
All of my local friends and neighbors also have these shocks, and they haven't had any problems. Hmmm????
Hmm....maybe you're right. The design could have changed. Yes, the shafts on mine are 4.2mm, mine came with bladders, but the caps are not vented.Idk unless they changed the design since I bought mine. You mentioned yours had 4.2mm shafts, mine are 5mm. Do they still not come with bladders and is the cap still unvented?
Did you have leaking problems with yours?
Ohh dang. Yes, that is a lot of oil. You should've complained. Maybe the seller would have sent you a new set. I can see why, you don't like these shocks. How long ago did you order these?They leak just as much as the stock ones, look at the oil all over the bag. The oil even leaked through the bag.............
