- Thread starter
- #21
Would I need just the mount? Or the version with the center differential cover?+1 pps - have on my mojave and it's awesome.
Honestly it's worth the money to get the full kit. You won't regret it!Would I need just the mount? Or the version with the center differential cover?
ok, i highly recommend it, but the one problem is that when you use it, you then need it for all your cars.Thinking I might order one of those nifty PPS mounts
alright brother!ok, i highly recommend it, but the one problem is that when you use it, you then need it for all your cars.
also, get the full kit, not just the mount. don't jip yourself!! you will end up ordering the full kit weather or not!! haha!!
No. I got it sorted with a dremel and a spade bit. Now the diff cover it putting too much pressure on the center diff and doesn't roll freely.I thought the pinion was supposed to go the other way...?
Is the shaft long enough??
I'll have to measure it and report back!I'm waiting for the same part to finish mine... Is that pinion much larger than the OEM (where the grub screw goes) or it is the new mount gap to small for the pinion to fit in??
I hope is just a matter of fiddling a bit... IT is a lot of money in alloy and they should fit straight on....
I'll definitely do that!Send PPS a message. I don't think I've heard of many issues with them. They are generally regarded as top of the line. A center diff issue is definitely something they should be able to remedy if it's a manufacturing issue.
