Matt miracle
- Kraton 4s
Is it okay to run the DB backflips 6s on my kraton 4S
I like the Talion shocks with Kraton springs on my K4S. I use 80W oil.Okay thank you I appreciate that I found the right ones and ordered them I guess I'll have to send those back he's the only thing I could find then when I got them to the door outside wow those are bigger they're not much bigger but they're bigger
If you could could you recommend me some good aluminum shocks to get set up for bigger jumps
Also be aware that your chassis may not be able to bottom out due to the taller tire. This will break shock mounts, shock rod ends, or arms.Building off this thread since I’m about to do this but to my 4s outcast.
Im putting my stock 4s outcast backflips on my K4S and ordered a set of the 6s backflips to give my O4S a taller stance and see how it performs.
I’m running a 3674 2200kv motor with stock 13t pinion. With a lower kv motor, should I still worry about temps? I’ll see if the diffs hold up.
