What’s the other end of the can look like?Is it on the way out? At a dead stop barely pushing with my hand it would hang up..
I meant the inside where the windings areOutside is clean..
The back end is probably more indicative of failure or not. The parts I can see look worn but not dead. Might want to get a can of motor cleaner and see how it looks after cleaning. Don't forget to lube the bearings with a good synthetic bearing oil.Only pulled the one side off..
What ya think??The back end is probably more indicative of failure or not. The parts I can see look worn but not dead. Might want to get a can of motor cleaner and see how it looks after cleaning. Don't forget to lube the bearings with a good synthetic bearing oil.
The burnt spots are a bad sign ….
