Is MEGA hydroplane possible?
LoganH
Ohio
Is it possible to hydroplane a Fury MEGA? And if it is, can it be done with stock tires?
Not a 2 wheel drive. As soon as you hit the water the front wheels will stop spinning, and will begin to plow the water. And shortly there after, you will be knee deep in water trying to find your truck.
I have seen it done with a 2WD, but, that had paddle tires on the back, and ski's from a snowmobile on the front, as well as a brushless set up on 3S.
Depends on the size of the body of water. My son takes his Fury Mega (new tires rear, worn tires in the front) across an 8 to 10 inch deep puddle that’s about 12 feet long and it does it fine in a straight line, but that’s with about 50 feet of momentum. Not sure how far it could go otherwise.
