Paultro84
I have a 4s lipo that isn't acting right. I set my charger to 5 amps, it's a 5200mah, but it will only charge at 3 amps. When I storage charge it, default setting is 1 amp and is not adjustable, it only takes .3 amps. With my 2- 3s batteries or my 2- 2s batteries it goes up to 5 amps until it's almost charged and then it starts to drop down. When running the Outcast and the LVC kicks in with the 2s or 3s batteries they're down to 3.4 volts faithfully. But the 4s pack drops down to between 3 volts and 3.2 volts. And when I charge it after the LVC and check each cell they're all different. 3v, 3.1v, 3.3v and 3.5 v. Should I just get rid of it?
