Guisseppe Leandro
- Typhon 6s
I replaced my motor after overheat problems (magnets are broken in the motor). Now I can only stear, but throttle gives no reactions. Is my ESC gone?
I’m a noob (just a few weeks into this fabulous rc racing). can you exploit me what the Rx is?Rx I bet is toasted.
If you mean the reciever, is it still possible to get a stearing reaction? Cause I can still stear...I’m a noob (just a few weeks into this fabulous rc racing). can you exploit me what the Rx is?
Thanks for your explaination?. The fan is working.Rx is short for the Reciever that is listening for your remote (transmitter) to tell the car which to steer and how fast to drive.
I had the same issue once where my Rx before it totally died would only let me steer but no throttle. Then it shortly died and wouldn’t allow for either.
This happened when the esc fan stopped working and the esc shut off
Yes, I can steer. Motor is connected with the matching colors (blue on blue, orange on orange and yellow on yellow).Your receiver is just fine, you said you can steer.
Check the ESC wire and calibrate your ESC to the transmitter. Make sure the new motor is plugged in right.
Thanks for the tire advice ??.Yes it's in the manual and also on youtube (throttle setup). Careful, I'd take the tires off, ideally nothing should happen but...
Are you sure the motor is connected right? No broken wires or bad solder joints? What motor did you install?
The motor burning out should do nothing to your calibration.
