I have fit up to a 29T pinion, but had to shave out some of the power module plastic to get it to fit using an HR motor mount. You can simply elongate the Arrma holes too.Hi,
Is there for the Arrma 3s series a motor mount which will fit a pinion bigger than 26t. I barely can get a 26t in it. But want to go with a lower kv motor an bigger pinion!
Thanks, Sam
