Trevor Park Jones
Do any program cards work for the blx100 at all?
Awesome, thank you very much!
Thank you very much! I'll give it a shot.You don't really need one. You can program all the settings on the ESC using the set button. It may be a little confusing at first, but it's really simple once you understand it. Here is the manual explanation and a video that shows you how to change punch.
In the manual you'll see there are 5 Variables:
1. Low Voltage Cut-Off Threshold
2. Punch
3. Brake Strength
4. Running Mode
5. Motor Rotation
In the video, he changes the punch. So you hold down the set button until you get 2 green beeps, which corresponds with the 2nd variable, Punch. Then he sets the punch to level 5.
If you wanted to set brake, you would hold down the set button until you get 3 green beeps, corresponding with the 3rd variable, Brake. Then set the brake level anywhere between 1 and 7.
When the level is set at 1, you will get 1 short beep. Level 2, 2 short red beeps, etc. But you should know that level 5 will be a long sustained beep. Level 6 will be a long sustained beep followed by one short beep.
No problem! It can happen.After seeing the post with the video, I remembered that I was actually thinking of updating software - nothing to do with the program card. Sorry for the misinformation!
