I've been trying for an hour.
Yes it's 13t pinion.Doesn’t look bad, are those the same pitch gear?
Looks good from here:I've been trying for an hour.
+1You can not check mesh without the other half of the module in place... The picture can't tell you anything unfortunately..
+1
I normally put the module and spin the spur, if it spins really easy then it’s to loose or if you hard to spin is to tight.
Not the best method but it’s they way I do it
Maybe @3d-rc.myshopify.com or other 3D printer guys on the forum could make a half housing so you see the mesh and set it with the slipper in the correct position.Yeah, you can surely get close with it open.. but once done, it should be assembled and checked for tick all the way around..
It drives me slightly crazy every time I see a video of mesh final set with the module open.. nothing to hold the slipper assembly on axis, they wobble around in all kinds of directions when open and supported by only one bearing like that...
If you can hold the slipper assembly true to the bearing face with pressure you can nail it the first time, but it should always be checked assembled, no matter how sure you are..
The motor screws can be tightened just enough to hold it still, but able to move with a little persuasion, assemble the module, (doesn't even need screws) check mesh tick, manipulate the motor to the proper tick, pull case half and tighten the screws down.. reassemble with screws and check one final time..
Too loose IMHO.I've been trying for an hour.
