Senton Is this good mesh just got a new motor and a 20t pniont
1999fd
Greece
  1. Senton 3s
I'm not good at mesh. This is second try.
djrahbee
Send-Flip-Break-Fix-Repeat 🤙🏼
VA
  1. Infraction
  2. Kraton 8S
  3. Kraton 6s
  4. Kraton EXB
  5. Mojave
  6. Outcast 4s
  7. Outcast 8s
  8. Outcast EXB
  9. Infraction 4x4
Looks like you need a little practice taking that transfer/gear case apart...🤣 Gear mesh is not just visual but also an audible thing. Now I will let the more qualified reply to this. Good luck!
Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
@Tex Koder Need some help here!
What happened to your Power Module casing!?
Well, from the two pics provided.. the mesh looks alright..
Do you hear a slight clicking sound if you shimmy (rotate slightly) the spur gear back and forth?
1999fd
Greece
  1. Senton 3s
Yes I hear the sound. I had a spare one and I cut to make better mesh. I'm not good!!
1999fd
Greece
  1. Senton 3s
Your power module casing needs to be replaced. The dirt and debris ingestion will tear up your spur gear, bearings and even the pinion very quickly. Getting the mesh right is your second concern.
Okay.
Then go out and have a good time.!
See how it performs.
does this sound fine? First time on aluminum.
RedOctobyr
Lowell area, MA
I think I have used paper to set pinion mesh, but it's been a long time. I think (for aircraft) I was usually adjusting it without paper, until I could feel just a tiny bit of movement from wiggling the larger gear. So it was close, but there was still a small gap.
But if paper is a better method, thank you, I should try that.
Velodromed
One to turn, two to burn.
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
That’s just a thing that some people do. They’ll cut a hole or a spot out of the rear of an extra spur case so that they can visually see the mesh. It’s extremely difficult to set proper mesh without the case being on and tight, so this is a crutch to help that.
It would be better to post a video of you rocking the spur gear back and forth so we could hear the tiny bit of clicking a good mesh gives you. From the sound of the video you posted it seems OK, but still that’s how I always do mesh, from the audible clicking sound it makes going back-and-forth.
Maybe it’s the photo angle, but is the pinion gear .08 mod? For some reason it almost looks like mod 1…
Johnny b
Florida
  1. Senton 3s
  2. Typhon 3s
Interesting...I learned something...makes sense regarding the hole cut! I was concerned he was going to run it that way.
1999fd
Greece
  1. Senton 3s
Vorteks pinion 20t 0.8 mod
1999fd
Greece
  1. Senton 3s
I believe with 0.8 mod you want it a little tighter.
For mod 1 you would set it up about how you have it pictured.
Even tighter??!??!! I can't do that. It's good enough for me
24# copy paper is your best friend. Looks like Chucky attacked your motor case.
Christmas Horror GIF by absurdnoise
YouTube life hacks fault 😂 for easier mesh set up
LibertyMKiii
Aerodynamics speed junkie
Dallas TX
  1. Limitless
  2. Mojave
  3. Typhon 6s
Geing metal gears it should be fine. A looser mesh reduces friction so the motor will be happy.
Only issue is where there is some flex in the motor plate or chassis and the gears pull apart another 1-2 mm you might shred em.
1999fd
Greece
  1. Senton 3s
I am not bashing that hard. Maybe some jumps but not that high. Also alot of people told me I'm good. Anyways killed the slipper clutch before I could run it. It was brand new.
