Kraton Is this normal or is it bent?
-Dusty-
Canada
  2. Outcast 6s
Trying to troubleshoot some stuff. I am having issues with my center diff binding. I was just wondering if its normal for the chassis to have a bend in it.
Edit: It was answered in another thread. Thanks!
Normal like everyone’s ends up bent sooner or later or normal like that is how they come? My lipos came out with a similar bend the other day, which lead me to find my chassis bent, which I assumed was from lawn darting large jumps. I tried to bend it back but didn’t have any luck. Not too worried about the chassis but bending lipos like that does not seem like a good idea!
Im not sure it is but I don't really know since I didn't check it when I first got it. Comparing the chassis with the outcast chassis, on the outcast there is no bend after the center diff area and its pretty straight all the way to the back. On my kraton the bend starts at the center. Plus it doesn't seem like an "even" factory bend.
It would also explain why the center diff bearings are binding. Really want to know for sure because I don't want to spend money on a new chassis and it end up not being the problem.
I guess Im just wondering if this bend could be the problem causing my center diff area to bind. I just want to be sure before I go buy a new chassis.
That looks like it starts to bend right under the motor mount, and it should be flat there.
That spot always gets a ripple eventually due to the fact that it's in between the front and rear chassis brace. Not much you can do to prevent it outside of running a tower 2 tower brace, and even then all it does is minimize the amount it can bend
Yea, Im going to have to do the tower to tower. Im still quite new with RC's and I been doing a few lawn dart landings. I think thats what caused the bend in my kraton, and I want to prevent it with the outcast as well.
Your Outcast should be harder to bend since it is a shorter chassis. The Kraton definitely flexes more. I am very familiar with the lawn dart landing! It happens when I mess up flips while jumping.
