When I sheared a output shaft at the pin, I took apart my front and center diff to check things out.
Upon inspection, I found equal spacers on each diff, and out of all the spacers, only one of them is flat.
I have new EXB diffs coming to replace the stock 6S BLX diffs, but I am still very curious if this is normal wear for a brand new Kraton BLX with 5 packs through it.
If its not normal wear, what causes it so I can keep an eye out for it, and correct it if I see anything with the EXB diffs.
