My first time soldering ec5 connector to ESC. connects okay to battery, but my shrink didn’t cover completely...?
This ^ they are nowhere near being far enough into the connector, some guys find it easier to go in the other way.For EC5 connectors, I find that you can get away without using heat shrink. However, from the looks of your pics, the connector doesn't seem to be seated all the way into the plug. It should sit flush - not with the end sticking out. Are you sure you're using the kind of plug that are designed for theconnector plugs to be pushed in from the bottom instead of the top?
I've used those exact kinds of connectors from Maclan. They're indeed supposed to be inserted from behind. Like slick2500 mentioned, you should hear a click when it's seated properly. I would remove the heat shrink, at least the bit covering the connector; otherwise, you'll have a hard time pushing the connector into the plug.I used these
And I assume after watching video inserting from behind is correct
?I’m not connecting to battery, I’m connecting to esc , I think my flaw is excess solder on the outside of the bullet. While didn’t give me “click”This ^ they are nowhere near being far enough into the connector, some guys find it easier to go in the other way.
