CrashBoom
- Twin Cities, MN
- Granite Grom
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Mojave 4s
- Notorious
- Outcast 8s
So I picked up an ISDT charger that supports their BattAir plugins, pretty handy system.
The plugins are bluetooth-enabled and plug into the balance plug on the battery (they are pass-through). You push a button on it to activate the bluetooth and then with an app you can see cell voltages, number of charge cycles, etc. You do an initial setup where you set the number of cells, capacity, desired charge rate, description, etc. If you have a BattAir enabled charger, it automatically sets the voltage and charge rate when you plug the battery in.
So the whole thing essentially makes any lipo "smart". The plugins are only 5 bucks a piece.
It's just kind of a neat system that saves some time and effort and helps organize your batteries.
