ea77
- Talion
Lost one these on one of my front upper suspension arms, and when I check the manual part number AR330218, it's only the caster spacer / caster shim is sold with the entire upper front arm! ugh
Think they are 1mm, 2mm, in thickness
I know from racing millimetres make a difference to the handling for an RC vehicle.
Can someone suggest an alternative? I'm sure I'm not the only one who has run into this issue.
Thank-you
Thank-you
